Carb o ring
Carb o ring
Does anyone know where I can get two o rings from
- IMG-20220921-WA0004.jpg (124.06 KiB) Viewed 3400 times
Re: Carb o ring
Hi Cliveo
This is a global forum so it would help to know where you are.
In the UK the best for dell orto is Eurocarb
https://www.dellorto.co.uk/
Look for vintage carburettors
Re: Carb o ring
I'm in NZ and I use the same supplier. They have almost everything for our carbs, I believe.
DD
DD
AntietamClassicCycle
Re: Carb o ring
Some information that may help:
https://www.thisoldtractor.com/moto_guz ... 6100-.html
Charlie Mullendore
Re: Carb o ring
Thanks All for your suggestions
I have now sourced carb gasket kits which have the o rings required
