Reinstating the electric starter part 2
unreal
Post by unreal »
Well all the electrics are working but....
It appears the customs have a different electric start casing, so the gear linkage fouls!
Does anyone have a spare standard electric start side casing?
Simon
Re: Reinstating the electric starter part 2
I would not think Morini could afford a different casing.
Has the linkage been changed, do you have rear sets?
Of course, I could be wrong, not unknown!
As far as I know tere are two diferent casing for Street- and Enduromodels. And of course the casings for the Kokussan alternator
unreal
Post by unreal »
Standard K1 linkage, case is definitely different, am I right in thinking the customs were left hand shift, which may explain it. I believe the off-road bikes were more cut away but may well work.
Post by morini_tom »
Can you post some pictures of what you have?
As above, I don’t believe there were any differences in the electric start case for the road models.
I’ve not got a decent picture of my k1 before I fitted rearsets but below is a picture from the sales brochure of the standard setup, and one of my bike now with rearsets and the longer cranked linkage
I have had the exact same K lever just touch the case and cause a selection issue. This simply required adjustment of the linkage. I think a friend had similar last year.
If the linkage rod is not a standard length ( I wished I had made a note of that when I made one from stainless steel) or cannot be adjusted to clear the case check that rod length.
I also am unaware of different e-start cases.
Measuring my rod, from the centres of each rose joint gives 151 mm ( home made rod)
'It must be a .....'
Trust this helps
Could alter the Excalibur cover?
top 500 road below 501 Camel (1).JPG (129.01 KiB) Viewed 6794 times
top 500 road below 501 Camel (4).JPG (135.09 KiB) Viewed 6794 times
unreal
Post by unreal »
Thanks guys, the case I have looks like the camel one. I have been looking at pics of my old Morini K, the linkage looks the same but the casing I have is definitely deeper. So cutting back won't work, so the hunt for a roadster case continues.
Attached are pics of my old bikes one and the one I have.
Try checking the “bits for sale” section at the moment, might be a case in amongst the parts ex Barcelona?
It was worth me looking at my gear linkage yesterday. The lever action was stiff. This turned out to be as a result of me trying to take up wear in the pivot bush/ frame using some thin shim metal last year. Some kind of corrosion I expect. Removed shim and much better but wobbly.
