software
twisty
Re: software
Post by twisty »
DaveH wrote:
twisty wrote:
DaveH wrote:do i need to load any software apart from ducatidiag
the software that came with my blue vag usb cable was infected with a virus so i had to bin it.
I'm wondering if i'm just missing the driver for the blue cable :|
Hi Tom...you need to install the drivers for the cable before connecting it ..try the following link for the drivers
http://www.ftdichip.com/Drivers/D2XX.htm
Install the driver first
When you plug the cable in it should then set a virtual com port number - look in Control Panel/System/Hardware/Device Manager/Ports (COM & LPT) to see which port you need to set in the Ducatidiag software to enable communication.
Ignition off
Plug VAG cable into computer
Plug diag adapter into bike
Connect +ive terminal (I used the large cable connection on the solenoid just behind the radiator on the LHS of the bike)
Switch on ignition
Launch Ducatidiag
Reverse to disconnect....
downloaded and installed the driver, which then gave me a com 3 port
the ducatidiag software seemed to recognise the port as the connect/disconnect bar changed to green.
no joy :?
no info from the ecu :cry:
tried changing the baud rate from 9600 to 38400 and from high and low init but still no handshaking from the ecu
i had two different leads to connect to the morini diagnostic socket so i know its not these cables. The blue vag cable lights up with power (maybe i've got a duff one)
Just checked the vag cable i bought and i notice that it's not compatible with can bus, so i wonder if that's why i can't get the ecu to read via the ducati diag. :!:
give me a hammer :twisted:
DaveH
Re: software
Post by DaveH »
Tom,
I'll email you a copy of my iso installation file if you pm me your address.
Dave H
Beta RR300 :mrgreen:
twisty
Re: software
Post by twisty »
seems if you are running windows vista you need to do the following
got to
computer
program files
locate the ducati diag program
left click on program to open files
right click on ducatidiag21
right click on "properties"
then compatability
tick the box to run in compatability mode
tick the box to run as administrator
click "apply"
then "ok"
hope this helps anyone
still don't know if thats why i can't connect but i'll give it a go.
Just to say that the ducatidiag owner deserves a medal as he is very helpful.
twisty
Re: software
Post by twisty »
problem was windows vista
Ducatidiag needed to be run in xp compatability mode.
without even registering, what a great little tool, switching fans, injectors, ignition on and off
like a kid with a new toy :wink:
this is what i got from the ecu
ECU model number: 23ACMOL49D
Hardware version: IAW5AMHW610
Hardware revision:: 00
Software version:
Software revision: 0000
Homologation No.. :
ISO code: 00 00 00 00 00
Tester code: admin
Production date: 20 08 06 11
Series No.. : 600C23S5I
Series No.23ACMOL49D
how do you read the production date is it 20/8/06 or 11/6/08
got the license , but what do i do with the cle.lic license file (dave)
does it automatically install or what
DaveH
Re: software
Post by DaveH »
hi Tom,
just copy and paste or drag the file to the installation folder...job done...I'll pm you about the licence file..I'm curious to see if they are the same...
Dave H
twisty
Re: software
Post by twisty »
what effect does the license have on the software (as i don't have it plugged into the bike at the moment)
Does it just let you reset the tps or are there other functions that become available. I was surprised how easy it was to use once i set windows vista to xp compatability mode.
Also is it possible to use the software with the engine running. :idea:
twisty
Re: software
Post by twisty »
any idea what these 4 buttons do
is the white box circled for entering a value or does it display one!
Ducatidiag Test & Reset_2011-03-31_15-43-17.png (3.18 KiB) Viewed 19213 times
DaveH
Re: software
Post by DaveH »
I think the software has been derived from a car variant...(the IAW5AM ECU was used in cars before migrating onto bikes...predominantly because of its small size I reckon).....anyway in some car guises there is more functionality contained within the ECU.
JP has re written the software to cater for as many bike ECU variants as possible...some of the functionality will not work on some bikes and will on others...it all depends how the ECU is programmed.
Right to answer your question Tom, the white box does not display anything...as I understand it, its a box in which a value is entered...the green button is then pressed and the ECU the undertakes a relevant test...whether or not these tests will work depends on whether the ECU recognises the command....if you see what I mean. It should cause no harm to the ECU if the command is not recognised....nothing should happen. (own risk etc !! )
Below is a list of commands & numbers (car related)
Coil 2 Control 1
Coil 3 Control 2
4 Control Stepper
5 fuel pump relay control
6 Control tachometer on dashboard
8 injector control gas cylinder 1
9 injector control gas cylinder 2
10 injector control gas cylinder 3
11 injector control gas cylinder 4
12 Control cooling fan relay 1
13 electric fan relay control 2
14 1 O2 Heater Control
15 Control 2 O2 Heater
16 Canister Purge Control Valve
17 Control Warning Lamp
18 H2O temperature control lamp
Hope that helps... :D
Dave H
twisty
Re: software
Post by twisty »
sounds right,
i put the value 2 in
jumped out my skin as the coil fired :mrgreen:
will a standard ecu tps setting be the same degree angle as a race ecu for open pipes :?: This is all new to me so i'm learning by asking
DaveH
Re: software
Post by DaveH »
twisty wrote:will a standard ecu tps setting be the same degree angle as a race ecu for open pipes :?: This is all new to me so i'm learning by asking
Yes.....TPS reset basically just tells the ECU when the throttle is fully shut so it knows the throttle position relative to the map cells throughout it's travel.....it's just the maps themselves that will differ :D
Dave H
twisty
Re: software
Post by twisty »
on the ducatidiag forum "ebi" say he can read a morini ecu using a program jps dump from the author of ducatidiag.
DaveH
Re: software
Post by DaveH »
twisty wrote:on the ducatidiag forum there is some info from one of the german morini forum members who is reading the software maps stored on the ecu's
They are talking about using "jps dump" to read the mapping
Any ideas what "jps dump" is and how do i use it :?
Jps dump is a non invasive program the author (Jean Paul) has written to extract the maps from the ECU...I have already asked him to send me a copy of the program but he has not replied....
Once extracted the maps can be analysed ...I think they are compatible with TUNE ECU software
If you contact him and get a copy, can you let me know.... :D
Dave H
twisty
Re: software
Post by twisty »
does any one have problems with the ducatidiag software.
I'm finding it totally unreliable, off the bike it works fine.
Tps and service reset buttons are ok and it works as if it has a license.
Connect to the bike and it constantly asks to be registered and the tps and service rest buttons dissapear.
I've done a new installation after uninstalling using windows vista and then relaoding the program and copying the "clic" license file to the program.
with the amount of hassle with the program i'm beginning to wonder whether i can trust it with my ecu in case it ****S IT UP
FIXED
THANKS TO JPS :P AT DUCATIDIAG.
P.S VERSION 22 IS OUT with dump tool and other features
