Corsaro runs rich
Raphael
Re: Corsaro runs rich
Post by Raphael »
Hello from Italy!
I know a special one guy on Morini ECU! He know Granpasso/Corsaro Avio/1200 sport/scrambler/9-1/2 ECU very well! He is working on Corsaro 140cv Ecu.
He has a web site http://www.mpx.joomlafree.it/ where you will have the option to download the valuable documentation and softwares required for uploading downloading and editing maps. He is also the founder of the best MM Italian forum www.corsacorta.it (with auto translate).
eMGe
Post by eMGe »
MonstroMorini wrote:Hi eMGe,
Mapping:
1) Did you perform tps reset?
2) Is everything else OK? I mean valve clearance, throttles synced, sparkplugs and batterie 100%? This should be checked first.
If above is OK, it should run (and keep running) with CORA, CORC and Ebi's maps, with lambda off.
Dashboard: MAE (the manufacturer) offered repair service, but they do not do this anymore (i have a cracked one as well unfortunately)
Here is a new one for sale, but not cheap: http://www.italobikes.com/de/foren/10-m ... ho-problem
Thanks MonstrMorini!
Original ducdiag doing strange things for me. It goes live, but can't adjust CO value (reset itself to 20) and can't reset tps to 0 (stock 2.7,reset 1.7). Now I overwrote the ecu by guzzidiag+iawwriter. Are you sure in ebi's map is open looped? So no need for the lambda right?
January I'll check all the listed things.
MonstroMorini
Post by MonstroMorini »
Yes, CORC & Ebi are lambda off.
You can use the guzzi diag for the tps reset and the co adjustment. Remember the engine must be running and above 40 degr for co adjustment.
The tps reset and co adjustment are found under 'actors' in the top menu of guzzidiag. Just choose a 8v 1200 guzzi model like grizo or 1200 sport to make it work.
MisterMorini
Post by MisterMorini »
Raphael wrote:Hello from Italy!
He has a web site http://www.mpx.joomlafree.it/ where you will have the option to download the valuable documentation and softwares required for uploading downloading and editing maps. He is also the founder of the best MM Italian forum http://www.corsacorta.it (with auto translate).
Hi Raphael,
I registered to that site & received a confirmation mail. I clicked on the link in that and then it said in Italian (used translation site) that the admin would be notified & activate my account. Well it's been a day or two now and still nothing. Any help would be appreciated.
Guy
PS: I'm also a registered user on "Corsacorta.it".
Raphael
Post by Raphael »
MisterMorini wrote: Hi Raphael,
Guy
I wrote to MPX owner :wink:
Now You will able to enter into http://www.mpx.joomlafree.it/ :D
MisterMorini
Hi Raphael,
Sorry for the late response, I was away for a couple of days.
Thanks a lot. I have access now. Great!
Thank you
Guy
Tinker
Post by Tinker »
Does anyone know if the bin files mentioned above are still available? Thanks
random
Post by random »
I have those maps in bin format, if you want I can send it to you. Just send PM. :wink:
