Bumblebee.
Sounds sensible fuse ratings given what circuits they are protecting - what about the main fuse in line with battery? Mine has a 25A fuse.
I popped the lid off the regulator box last night, the only things that you could perhaps replace are the 2 thyristors, everything else is "potted" in a grey substance, which was to be expected I suppose.
Once I have done the main fuse, and repaired the wobbly junction connector I will do another check of the charging voltage, given that all connections appear sound.
If it still fluctuates as it did, I had probably best replace the regulator.
One anomaly I spotted and that is a diode in line with one of the green wires from the connector panel (bottom row) not yet checked to see where the wire goes but I did check that the diode was OK and it was. Not seen this in any of the wiring diagrams. Anyone shed any light ?
Morini Newby charging question
Re: Morini Newby charging question
I don't know about the main battery fuse, I have owned four 31/2s the newest being a 1979 electric start model, not all at once, and none off them had a main battery fuse. Maybe yours was fitted by a previous owner? As you said, "badly"?
The diode in the green wire is protection for the electronic ignition system in case a voltage gets on the green wire. e.g. (1) In case the ignition switch develops an internal short circuit to green or (2) In case someone decides to put a tester with voltage on the green at the ignition switch terminals while fault finding. It wasn't fitted to early 31/2s but people sometimes retro-fit it.
Thanks Bumblebee - I always like to know what various bits and pieces do.
The in line battery fuse looks to be a "period" fuseholder, so may not have been fitted by the PO.
The electric start wiring diagram does show a fuse running from the starter relay to the fuse panel - fitting one in line from the fuse panel to the battery achieves the same result.
Totting up the total load (and assuming the fuse can't possibly be protecting the starter motor
) I would suggest if you have a standard (45 Watt or less) headlight then a 25A main fuse is ok... but if you have a 55/60 Watt headlight it might be a bit borderline for the fuse in situations when all the electrical loads are running together.
- George 350
Hi Andy,
Just a thought, but some multimeters can be affected by ignition interference and can give you odd/fluctuating readings.
Have you tried/can you try another meter?
Too high a voltage will overpower the battery and 'boil' the acid off. If battery is 'ok' it might be that you don't have a problem at all!
Regards, George
Regards, George
Good point George
The battery seems to hold charge OK, so perhaps I don't have a problem at all.
I do have an old analogue Multimeter, the checks I have done to date have used a digital one, I'll find the Analogue one and see what that says.
Thanks for everyone's help.
Final reply from me on this one.
Checking the voltage accross the battery with the engine idling it is around a steady 12v when the revs reach just under 2000 it goes up to a steady 12.5 / 13 so I am going to assume that all is well.
