Page 3 of 6
Re: Shop full of Spares. Stock from closed dealer in Barcelona
Posted: 27 Feb 2024 11:25
by Tom
Yes I used an exhaust clamp.
Here you go:
Posted: 28 Feb 2024 06:26
by Team Buffoon
Thank you for the pictures makes it very clear and thank you for the other responses.
Posted: 04 May 2024 02:04
by michaelt
Do you have any of the chain idler wheels for a Camel 501.
Cheers.
Michael
Posted: 04 May 2024 06:56
by ianlucas006
Hi Michael.
Away at the moment. I suspect not but will check when back. They are available. I am sure there was a discussion in Green Lane group recently. I do have a complete 501 Camel if you want another one. Just picked up in France! Thanks Ian
Posted: 12 May 2024 13:56
by Al B
You haven't by any chance got a Sport speedo cable have you?
Posted: 12 May 2024 20:40
by ianlucas006
I don't think so but will double check when I get 5 mins. Thanks Ian
Posted: 25 May 2024 01:06
by chrisMorison
Hi mate, Any 260mm discs?
Chris
Posted: 26 May 2024 08:13
by ianlucas006
Hi Chris
I may have but would cost a fortune to post to Australia! Which model as there are different hole centres and offsets.
Thanks Ian
Posted: 30 May 2024 00:36
by chrisMorison
75 350 Sport wire wheel.
It's 260mm x 25mm offset 6 bolt
Yes postage is a pain in the crack but I can't find one here. A Pantah disc might fit but they're pretty thin on the ground too.
Posted: 30 May 2024 16:12
by hombre
chrisMorison wrote: 30 May 2024 00:36
Th Pantah ones probably have a larger offset, bolts, ø are the same
Posted: 30 May 2024 16:41
by simonnorthroad
Hi Chris,
Ive got several Morini 260mm Grimeca discs here in the UK. They will weigh a ton to post though.
Pantah/Guzzi Brembo discs have a deeper dish.
I can send photos/get you a quote if you are stuck. I post books to OZ all the time
PM me or email:
moriniboy23@yahoo.co.uk
Posted: 07 Jun 2024 20:38
by ianlucas006
Hello Chris. I have tracked down the disc. It is a bit scruffy as the chrome has worn away as they do. Post to Aus is about £40! Which is more that I would want for the disc. thanks Ian
Posted: 12 Jun 2024 02:44
by vtwinanyday
Thanks I found lots for sale on ebay. I ended buying one from Italy after weighing up price v postage.
Cheers Chris
Posted: 26 Dec 2024 22:58
by Team Buffoon
Hi Ian - Merry Christmas,
Do you have a set of fork gaiters for a 501 Camel? 40x50mm x 29cm.
Posted: 27 Dec 2024 11:32
by ianlucas006
There are some NOS aftermarket ones in red. Top and bottom diameters are good for 501 forks. The overall length is about 40mm longer and the diameter on the bellows section is slightly larger than the originals. £10 Plus what ever the post is (prob about £4)
Thanks Ian
