Ignition Timing
Guzziando
Re: Ignition Timing
Post by Guzziando »
3potjohn wrote: 24 Aug 2025 18:32 Glad it is sorted- that photo was not of mine , just seemed clear. Mine shows the usual mix of age and “deposits”.
i thought it was too clean! A very clear picture though :D
Andy_C
Re: Ignition Timing
Post by Andy_C »
Just a thought re timing marks on the cam pinion and crank pinion.
As long as the cam pinion dot aligns with the mark on the crankcase, and the crank keyway aligns with the dot on the case, the position of the marks on the crank pinion dont really matter as long as you can get the belt on and maintain the position of the dot on the crank pinion and crankshaft keyway?
Is that right ?
Guzziando
Re: Ignition Timing
Post by Guzziando »
Andy_C wrote: 07 Sep 2025 16:11 Just a thought re timing marks on the cam pinion and crank pinion.
Is that right ?
Yes, that is what I did, it was coincidental that the other mark lined up when I did this, therefore making me believe that it had been fitted to the wrong mark.
