besides: your regulator also doesn't like the swapped battery connection
Mine arrived today, it looks very good. And after reading the installation instructions, some new skills for me to learn too! Win/WinKamel wrote:
Incidentally I received my Sachse unit today, and it looks extremely well made I have to say.
Kamel.
 My pleasure Andy, it only took a couple of emails to arrange. I don't know why more owners clubs don't organize something similar to be honest.AndyB57 wrote:Mine arrived today, it looks very good. And after reading the installation instructions, some new skills for me to learn too! Win/WinKamel wrote:
Kamel.
Thanks for your work to arrange it all Kamel, much appreciated.
Agreed, and like I said I really wanted to try the SWF system, but didn't get very much feedback about them.hendre wrote:I think Anne already has solved the frying issue when connecting the battery not correctly.
See accidents do happen. I was refitting one of the original indicators on my Camel while it was flashing and the chrome plating on the back of the reflector shorted the contacts and blew my brand new electronic flasher unit.huub wrote:not sure if you should expect electronics to be able to survive connecting the battery wrong.
i can for a fact tell you the regulator and rev counter of a morini does not ( dont ask....)
i doubt the sachse unit will , the one on my guzzi died in normal use...
 I rubbed that area of plating off so it won't happen again.
  I rubbed that area of plating off so it won't happen again.I paid nothing more, which is good! DHL contacted me late last week to say they had the package, it turned up Monday.Kamel wrote:My pleasure Andy, it only took a couple of emails to arrange. I don't know why more owners clubs don't organize something similar to be honest.AndyB57 wrote:Mine arrived today, it looks very good. And after reading the installation instructions, some new skills for me to learn too! Win/WinKamel wrote:
Kamel.
Glad yours arrived ok. did you get charged any import duty or VAT ?
Kamel.
I've a set on my desk, for a couple of weeks now, just for fun to see what they are up to or how much abuse they will standKamel wrote: Now if Anne can make a unit that will drive stick coils I'd definitely be up for one. Imagine, you could probably fit that in 10 minutes.
Kamel.
What is the electrical difference from stick coils to conventional coils?Kamel wrote: Now if Anne can make a unit that will drive stick coils I'd definitely be up for one. Imagine, you could probably fit that in 10 minutes.
conventional coils have a primary resistance of 3~5 Ohm and a reasonable big iron core to store the necessary magnetic energy, and a lead to the plughendre wrote:What is the electrical difference from stick coils to conventional coils?Kamel wrote: Now if Anne can make a unit that will drive stick coils I'd definitely be up for one. Imagine, you could probably fit that in 10 minutes.
Result!robint wrote:Mine installed, first kick start and steady idle at 1400rpm and a steady tachometer needle which is a novelty (no it's not stuck!). Fair bit of electrics to make up as used new coils (the PVL ones do just fit under the tank) and a bracket needed for the control box - under the left hand cover, otherwise straightforward and easy to get static timing on both cylinders. Using setting 5 that it came with but so far weather not exactly encouraging a road test.......
Cheers cliff for the arranging!
That's great news robint !!robint wrote:Mine installed, first kick start and steady idle at 1400rpm and a steady tachometer needle which is a novelty (no it's not stuck!). Fair bit of electrics to make up as used new coils (the PVL ones do just fit under the tank) and a bracket needed for the control box - under the left hand cover, otherwise straightforward and easy to get static timing on both cylinders. Using setting 5 that it came with but so far weather not exactly encouraging a road test.......
 The black box I may just velcro to the bottom of the tank so its accessible. It should keep it nice and cool too.
