new toy
lemans
Re: new toy
Post by lemans »
julianharty wrote: 06 Apr 2022 20:46 Is no news good news in this instance?
no, it has been reported two posts back, problem solved, no slipping clutch at WOT after cleaning
to be replaced by "misfire at high RPM and WOT".
will clean carbs first and report results
Re: new toy
Post by julianharty »
lemans wrote: 07 Apr 2022 18:22
Sounds like you're making progress, good stuff.
lemans
Re: new toy
Post by lemans »
took out the dental torture tools and replaced all gaskets, rubbers, atomizers, needles and floatvalves
although the bike started, idled and ran reasonably well, except for WOT, atomizers (T262) and needles (X1) were in a very bad condition.
so all have been replaced.
this hole in the rear carburettor wasn't plugged off as should have been.
the front carb had it plugged and according to all manuals, drawings and schematics I believe the hole should be plugged
it also confirms the observation of not being very responsive to the idle-mixture adjusting screw.
put some JB-weld on/in and rebuilt carb
testride scheduled for thursday
PHBH 26
slide 40
idle jet: 54
main jet: 130
other jet 48
atomizer: T264
needle: X23
floatvalve 200
have sets of T262 and X1 on stock.
the jetting is not standard, as is the exhaust.
appointment with startrick has been made
lemans
Re: new toy
Post by lemans »
solved, but in a totally different way as thought
after replacing all parts, rubbers, gaskets and balancing carbs, in the first testrun the misfire was still very much present,
present at all revs > 4500 rpm and >3/4 throttle. (indeed it hasn't improved)
checked all parts of the ignition system and even contemplated in reverting to the original unit :(
however, this mornig I changed the ignition for a spare unit and went for a testrun.
all was well for the first mile and then the misfire presented itself again and became more serious during the run.
last conclusion: it could be heat-related. so changed the original spark plugs (ND W20ep-u) for a set of NGK BPR7ES
although the heatrange isn't very different it completely solved the misfire.
next problem: in 5th gear the bike doesn't reach max revs, it stops at 6500~6900 rpm
Startrick is scheduled for next week.
https://swf-ignitionsystems.nl/wp-conte ... G_7450.mov
lemans
Re: new toy
Post by lemans »
slowly improving, the airbox is a pita when swapping needles.
the exhaust doesn't improve power.
we did a full day of testing together with the joungest son and a very enjoyable day indeed
https://swf-ignitionsystems.nl/wp-conte ... G_7465.mov
we ended with:
PHBH 26
slide 40
idle jet: 54
main jet: 120
other jet 48
atomizer: T268
needle: X40
floatvalve 200
lemans
Re: new toy
Post by lemans »
16 months have passed since last post, bike is running fine without major modifications. and used as the daily ride.
fitted new chain and sprockets, 14/44 and 520. the rear sprocket could be 45 or 46 as the engine does not reach max revs in top gear
still 152 km/h has been reached on the german autobahn.
the bike holds itself well in a gaggle of more modern ones, but you'll need all the gears and revs to keep up. on secondary roads only.
visiting the ducati monthly club meet, of course with the 500
https://swf-ignitionsystems.nl/wp-conte ... XB3854.mp4
huub
Re: new toy
Post by huub »
that starts remarkably easy!
lemans
Re: new toy
Post by lemans »
huub wrote: 22 Sep 2023 10:37 that starts remarkably easy!
well, did some work on the carburation with Starttrick from Terborg. When used regularly she's an easy starter. if left over for two weeks you'll need two ~three kicks. Choke should be off fairly quickly but then you have to be carefull at the first light. Pulling away cold and no-choke can be tricky. After one mile all is fine.
lemans
Re: new toy
Post by lemans »
this weekend off to the local classic races in Gramsbergen. The MM500 is running well and fun to ride. as mentioned before; on secundary roads the bike will hold itself well against the modern ones. although you need all the revs and gears.
Re: new toy
lemans wrote: 23 Jun 2024 20:40 this weekend off to the local classic races in Gramsbergen. The MM500 is running well and fun to ride. as mentioned before; on secundary roads the bike will hold itself well against the modern ones. although you need all the revs and gears.
Very pretty and glad you're riding it well.
Re: new toy
Beware the fake spark plug. Can cause misfiring etc. There are a surprising number of fakes on the market. Resistance using a multimeter can be useful. I’ve tried Denso IW22 and 24 but had to revert to NGK on one after a plug failed.
Re: new toy
Hi,I've used only Denso plugs on my Morinis since the late 1980s, due to poor performance and longevity from NGKs
I used to get them direct from the importer and now from the Green Spark Plug Company; mainly as they have always been difficult to source
Don't be tempted by really fancy/expensive new versions of plugs as they can give problems, not being designed for carb/choke type starting/running
lemans
Re: new toy
Post by lemans »
as for plugs:
- I do not buy these anymore on Ebay, to much fakes around and to many failed plugs after a short period of running
- I only buy from a local shop with auditable sourcing from NGK
lemans
Re: new toy
Post by lemans »
Last friday used the MM500 as the daily transport to work, 205 km single trip. The first stretch to the A28 a little bit hesistant but then the fun started.
refueled after 180km, a welcome break as the bike is a bit small. The acoustic properties of both the Benelux and the Botlektunnel are very good :).
The return trip again very pleasant, TT-weekend so a lot of motorcycles on the way up North. Tagged along with some french and UK-bikers. Let them go after a couple of miles. Very high speeds in the centre line of two-lane slow moving traffic. not my cup of tea.
although when I arrived home the kettle was already on as the bike is a bit loud. will be solved in the near future when I get the castle-nut in the rear cylinder head to unstuck.
