Page 5 of 6
Re: Shop full of Spares. Stock from closed dealer in Barcelona
Posted: 09 Mar 2025 16:44
by ianlucas006
Hi Norton
Most of the kickstart gears are 20 teeth which is I think standard 350. I have one at 19 teeth which I believe is 500 6 speed box. The 5 speed box is 23 teeth. Do you know which you have?
Posted: 11 Mar 2025 13:51
by Norton
Hi Ian,
I’m sure it is a 5 speed box, will double check though. I have sent you a PM with my number.
Norton
Posted: 13 Mar 2025 19:29
by davel182
If it is any help the kickstart gear of the 250T is the same part number (14.04.25) as the 500W (I have never heard of a 250H - I believe the 125 used that letter).
Re: 500 Exhaust Collets
Posted: 18 Mar 2025 01:25
by Team Buffoon
Thank you Ian, they are proving to be a rare commodity. 500 exhaust collets that is
Posted: 04 Apr 2025 10:12
by mikebn
HI iAN
I NOW ALSO NEED A LOWER CAMSHARFT CAMBELT PULLEY
MIKE SMYTH
Posted: 06 Apr 2025 20:13
by ianlucas006
Hi Mike
Sorry the system failed to tell me I had a new message. I will try and look tomorrow but have a lot on and am out all day Tuesday.
Ian
Posted: 15 Apr 2025 16:14
by Bison
Hello Ian,
Would you have a useable pair of Marzocchi stanchions for a Strada K1?. 605 long, 1.5mm pitch threads at the top nut.
Thanks,
Alan.
Posted: 15 Apr 2025 20:23
by ianlucas006
Hello Alan
I got 1 NOS 35mm stanchion in the stock of bits. It is 601mm long however. Machining tolerance? I know they are supposed to be 605mm. I have a feeling I found some new ones recently that were not too expensive. If I remember where I will let you know. Cheers Ian
Posted: 16 Apr 2025 07:39
by Bison
Thanks for the reply Ian.
I have hopefully found 2 NOS ones in Germany, they should been their way soon.
Is that red K1 fuel tank still around?, if so, what nick is it in?.
Alan.
Posted: 16 Apr 2025 08:23
by ianlucas006
Hi Alan
That tank and most of the others have gone. Good luck with the stanchions
Posted: 16 Apr 2025 08:40
by norbert
ianlucas006 wrote: 09 Mar 2025 16:44
Hi Norton
I can confirm this:
- 19 teeth: 500/501 6-Gear (the only one with somehow "pointed" teeth)
- 20 teeth : 350
- 23 teeth: 500 5-Gear and 250T (as far as I know, the whole gearbox is identic)
- 44_kDSCI0053_1.jpg (29.46 KiB) Viewed 9640 times
The upmost sprocket on the kichstart shaft should be carefully chosen to fit the teething (there are slighty diferences concerning the form of the junction teeth!)
The rest of the kickstart mecanism is allways the same at least in 350, 500, 501 and 250T
Primary gear:
350: 29/66
500/501: 31/63
both are 23 mm thick
Posted: 16 Apr 2025 09:10
by norbert
In 2011 I tried to resume the main diferences between the 500/501 and 350 motors in the german forum.
In the 4th post you find the results.
I don´t have the time to transduce all that right now, sorry. If the admins like to pas that informacion to an other place of the forum: go ahead!
https://www.ital-web.de/forum/viewtopic ... chiede+501
Long live the internacional morini solidarity!!!
cheers
Posted: 27 Apr 2025 09:40
by Norton
Thank you for the response Norbert. Useful information
Cheers, Norton
Posted: 05 Jun 2025 14:27
by Wassuck
Hi Ian,
Just checking, what parts for 250s do you have? Was that a slightly dented 250 / 125 that I saw in your first photo?
Look forward to hearing from you.
David
Posted: 05 Jun 2025 14:48
by ianlucas006
Hello David. Yes there was a 250 tank but now gone. I have some 250 forks and yokes still for sure. What other specific bits do you need and I will have a look. Thanks Ian
