I have read the 3 1/2 Service Manual and the Manual for the 125-500 models, and other sources and have received conflicting information on the choice of plugs and the gap value. Most books say B7 NGK, others say this is too cold and B6 plug is required.
I have read recommended values ranging from .5 to .7 to .9mm, depending on the source. My experience with the Ducati Electronica ignition would lead me to go with .7, but that is quite a range.
What is the recommendation here?
Thanks.
									Spark Plug Choice and Gap
1982 Laverda 180 Jota, 1974 Laverda SFC, 2010 KTM Adventure 990, 1992 Ducati Superlight, 1993 Moto Guzzi Daytona 1000, 1983 Moto Morini 500 SEI V Sport
						Plain old BP7ES work just fine for me.
BP7EV have the 'wire' centre electrode and help with a slightly weak spark, but wear faster.
The exotic materials simply allow a small diameter electrode to last.
If you don't put many miles a year on the bike, save your money.
I'd suggest that if you're fouling grade 7 plugs, then you have an underlying problem with mixture or worn bores/rings.
