It looks like I'm going to be having some 2+2 cams ground.
Cost is likely to be £110 exchange and I need a 20mm base circle cam as a donor. A Sport cam is best to guarantee a 17.5mm base circle. If I have to provide a core it will be an aditional £35.
If you would like one please let me know.
2+2 cams
2+2 cams
John Bunting
Re: 2+2 cams
Hi EV,
If you don't get enough takers to make it worthwhile to grind 2+2 cams, I don't know what your minimum order is? It is possible I could offer you an original 2+2 I bought in Italy, more expensive than the regrind though!!
Unless I find a 501 engine to build up and they seem to be scarce, I don't think I'll be going down the more modified engine route.
