Dart Oil Warning Light
The Cagiva era Morinis
Does the Dart Oil Warning Light stay lit with the neutral light and go out when put into gear, as a warning to check the oil occassionally, or is this a wiring fault?
thanks,
MM
Re: Dart Oil Warning Light
That's normal, my Gilera CX does the same. It's to test the oil warning light bulb.
ok, thanks. No need to pry then!
MM
