For sale:
350 frame & swinging arm, genuine English not grey import, powder coated, straight down tubes with registration documents - £150. If you want the swinging arm converting to fit & forget bearings - no greasing, add -£20.
2 off mechanical rev counters, 12k & 10k with angle boxes good condition - £50 each.
2 off speedos 160kph & 200kph one better than the other - £15 & £20.
350/500 exhaust shield fluted type - £25.
350 exhaust collets 8off - £20 the lot.
140watt stator in good condition, 48v output on ignition at cranking and 16amps charge rate to battery - £150
Transducer 1st series 350 No 323921 - £40.
Brand new stainless steel taper head conversion with bearings. These really do improve the handling from the bicycle ball and cone as fitted as standard - £110.
Kanguru X2 2-2 stainless steel exhaust pipes brand new - £50.
350 Strada engine was running when removed but would suggest a rebuild, missing stator and right side cover - offers.
Please PM me if interested in any of the above, items located in South Shropshire.
