Oil Cooler
SoloFrenos
Oil Cooler
Post by SoloFrenos »
Hola,
Does anyone on here know if its possible to fit an oil cooler to my 350? If so what sort of work is involved?
hendre
Re: Oil Cooler
Post by hendre »
SoloFrenos
Re: Oil Cooler
Hi Hendre, thanks for the info. Does not look too difficult a job and probably worth it to give my little engine a happier life down here in the heat.
Re: Oil Cooler
Before wasting a whole load of effort fitting an oil cooler, why not do something much simpler, like fitting an oil temperature gauge.
The oil strainer cover is an obvious place.
SoloFrenos
Re: Oil Cooler
Hi Paul, sounds easier but sorry to ask......any ideas how exactly i would do that? And obvious question but what sort of temperature should the oil be?
Thanks, Tony
SoloFrenos
Re: Oil Cooler
Ah ok, i seem to have sussed it myself. Buy a suitable sender, drill/tap suitable hole in cover, wire to gauge. Does sound simple. But not sure on temp, does around 80 sound about right?
George 350
Re: Oil Cooler
Post by George 350 »
Hi Tony,
Re: the ideal oil temp. For older oils meeting the spec SF-CD, typically mineral oils described as suitable for older cars, the upper limit before carbonising occurs is about 140 degC. For more modern fully synthetics (SF-CJ+) it is around 180 degC. Semi synthetics are somewhere in between. A good working range is between 90 and 120 degrees. Any lower and unburnt fuel and water from blowby will not evaporate properly from the oil.
Bear in mind that Morini's are Italian, and it regularly reaches 38-40 degrees ambient (occasionally even higher) in summer, and Morini are known for their robust engines, the need for a cooler is questionable. In my view, it is only if the engine is covered by a fairing (eg. the Dart) or you are super tuning it when you would need a cooler. Remember that cold oil costs you power with the extra friction!
Regards,
SoloFrenos
Re: Oil Cooler
Hi George,
Hmmm that's a very good point i'd never thought about that, maybe i'm worrying about nothing. Thanks for the advice.
Cheers, Tony
