Flywheel Nut Torque
ipaulog
Flywheel Nut Torque
Post by ipaulog »
I'm just putting things back together after a belt change. I suppose that once you've compressed a thick spring washer you're done but is there a torque setting for the flywheel nut? I can't see a value in my workshop manual.
Thanks, Paul.
Re: Flywheel Nut Torque
On page 13 of my copy of the blue book it says generator rotor nut 6.5mKg which is 47ft Lbs or 63Nm for a 250/350/500 Morini and 5mKg for the 125.
ipaulog
Post by ipaulog »
Thank you.
3potjohn wrote:On page 13 of my copy of the blue book it says generator rotor nut 6.5mKg which is 47ft Lbs or 63Nm for a 250/350/500 Morini and 5mKg for the 125.
