rear sprocket carrier bearing
markw
Post by markw »
Hi
I need to remove the bearing from the rear sprocket carrier on my 500 sei-v.
Is it a case of heating the carrier and knocking out the bearing from inside ?
Any advice ?
thanks
mark
Re: rear sprocket carrier bearing
I did mine a couple of years ago-actually I cannot recall a problem. I know I used large rawlbolts expanded in the wheel bearings,with copious boiling water on the hubs and knocked those out by tapping the rawlbolts. I think I must have done similar on the sprocket carrier? Should have made a note I guess
