So where does this bit go....
bobajob
Post by bobajob »
Embartassing question of the day:
Where does this bit go?
where dos this go`/
where dos this go`/
I'm refitting the rear wheel after completely stripping if for painting. I put all the spacers, washers etc on the spindle in the correct order for safe keeping but can't work out where this part goes. I reckon it's on the sprocket carrier side. there doesn't seem to be space in between the wheel bearing and carrier (inside the cush drive) and can't see where else it would go.
thanks
Rob
Re: So where does this bit go....
That's the inner race from a broken bearing.
bobajob
Post by bobajob »
Thanks Paul, no idea why I put it on the spindle when I bagged up the parts. I've learn't that you just can't take too many photos or make too many notes when stripping a bike down to the frame.
