carb question
				mad muller
carb question
I will put this to the tech folks on the forum  , running with pod filters thinking of upping the pilot jet sizes anyone else done same as a little weak on idle. thanks muller.
						Re: carb question
I usually find that I'm fitting smaller idle jets for modern fuel.
What makes you think you're running lean?
				mad muller
Re: carb question
thanks for reply, I have to have the idle set fairly high to get a decent pipe sound, on nearly 2k showing on the tacho any slower it sounds  pretty feeble like a sewing machine with a poor exhaust note if you know what I mean, worse when hot with the occasional dead spot on first throttle opening, bike runs fine through the rev range and plugs also nice sandy colour, that's got  me thinking about pilot jets they are original ones , and would going bigger help .    thanks muller
						Re: carb question
A stumble when pulling away which gets worse as engine temperature rises indacates you're running rich.
I usually fit 43 idle jets.
				mad muller
Re: carb question
I see were your coming from on going smaller on the jet size, I suppose its more of style over substance with the pod filters only thing to do is try a few out see if it improves the running, if anyone has any pilot jets going spare please pm me, thanks again for reply . muller
