Headlight wiring
MoriniMike
Headlight wiring
Post by MoriniMike »
Hi guys, I've spent 3 days trying to get the headlight to work. Wired up as blue book for 6 pole switch but can only get a side light. That goes out when switched to main beam. Is the handlebar switch connected to earth?
Anyone got a diagram of switchgear to headlight?
Mike
Chips1953
Re: Headlight wiring
Post by Chips1953 »
Did you get a reply on this?
My switch has been butchered by the previous owner and am looking for some info?
Singer 185K
Wheel Horse commando 7
Honda SS90 1965
Chips1953
Post by Chips1953 »
Well I worked that one out, so if you read this you'll know I don't need you to replay.
Thanks.
Singer 185K
Honda SS90 1965
TurboRestorer
Post by TurboRestorer »
Try this wiring diagram. The headlight housing is an earth point as are the indicator mounts, these are a known issue.
[img]
Moto Morini Wiring Diagram (Mod 350).jpg (167.97 KiB) Viewed 7666 times
[/img]
This diagram has been modified to suit our Morini so there may be some differences but all the electrics work, headlight flasher is on dipped beam from factory.
ZRX1100 1999
KLR650 1990
750 TURBO 1984
SV650 2001
MOTO MORINI 3 1/2 STRADA 1981
Chips1953
Post by Chips1953 »
The problem with mine was that the headlight had been changed from the original and a separate + feed had been put into the equation. There is a link in the original headlight switch that is supposed to feed the main/dip switch for either Main or Dip. This was not the case with mine, I don't know why. I inserted a link from the Light switch "on" connection to the Main/dip switch and removed the secondary + feed. Bob's you uncle.
It has an MOT now but the DVLA have just rejected my Registration because of a duplicate Spanish Registration document. How to remove the "Duplicado" stamp on the Log book?
Singer 185K
Honda SS90 1965
