500 Discs.
500 Discs.
Post by Mark »
Hi all.
Can anyone tell me if discs from a 500 are the same as for the 350, ie, a straight no hassle bolt on, in this case for a 1983 model K1?
Thanks.
morinipete
Re: 500 Discs.
Post by morinipete »
Yup, should be. Rear disc is the same as fronts too. I think the 250 was the only one to have different (smaller) discs.
Pete
Re: 500 Discs.
morinipete wrote:Yup, should be. Rear disc is the same as fronts too. I think the 250 was the only one to have different (smaller) discs.
Pete
I'm pretty sure the 250 2C , 250 single and even the 125 H used a 260mm front disc.
Re: 500 Discs.
Post by Mark »
Ok, thanks for the info guys.
