Pilot jets
penman
Pilot jets
Post by penman »
Hi all,
I would be interested to know what size pilot jets people recommend. I've tried 50, 44 and 42, those being the sizes I have to hand. 42 is definitely the best for me, but I suspect I could go smaller still. The problem is that the progression orifice mixture is only controlled by the size of the jet and I find that with the standard 50 jet, it tends to hesitate coming off idle - presumably due to the difference in modern fuel. You can improve it a bit by making the idle mixture leaner, but that's at the expense of reliable idling, especially when not fully warm. Moving to a 44 jet seems to be quite a big improvement and 42 is better again for me. Even going from 50 to 42 only needs a small adjustment of idling mixture.
Anyone else been down this route?
Regards,
Joe.
1984 Moto Guzzi V65
1969 Honda CB450
1975 Triumph T160 Trident
2019 BMW F750GS Sport
1978 Morini 500
Re: Pilot jets
I'm running 45s - but that's on PHBH28s.
Re: Pilot jets
Time for a larger slide cutaway as an alternative way of leaning out progression.
No amount of playing with the idle jet would sort my 125H out, but going from a 40 slide to a 50 did the job.
penman
Re: Pilot jets
Post by penman »
EVguru wrote:Time for a larger slide cutaway as an alternative way of leaning out progression.
Thanks Paul, that does make sense. The only slide now stocked by Eurocarb is 60, which may be OK but at £45+VAT+post EACH, it's not a cheap option. I could easily modify the existing 50 slides, but that's a one-way trip. So, I guess I'll have to explore the possibilities of fiddling about with pilot jet and atomiser first. 42 pilot is pretty close, I may decide to live with the small hesitation.
1984 Moto Guzzi V65
1969 Honda CB450
1978 Morini 500
Re: Pilot jets
No shortage of VHB 7147.50 slides in my shed. Give me a shout and I'll post a couple.
