Kanguro tank bolts
Coxey
Kanguro tank bolts
Post by Coxey »
Hi
Does anyone have a couple of spare bolts that hold my Kanguro X3's tank in place? Also a couple of lengths of new fuel pipe would come in handy too (I don't live near any bike shops :oops: !)
Many thanks
Rob
___________________________________________________
1989 Kanguro X3
BMW K100RS
Re: Kanguro tank bolts
Coxey wrote:Hi... I don't live near any bike shops :oops: !
Many thanks
Rob
Neither do I! I tend to use ebay for general stuff, NLM for more Morini stuff (very good mail order service).
Someone will confirm the size required. M7 for the tank hex head set screws I think, but not sure of the length. As ming says, lots of Ebay suppliers for metric fasteners (including in stainless steel). Same for fuel hose (just check the ID required and decide which type you prefer) which you can often get in just a 500mm length.
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
The two vertical ones with the rubbers? Don't recall any others.
MickeyMoto wrote:The two vertical ones with the rubbers? Don't recall any others.
If I remember correctly early 350s used bolts through 'plates' that formed the front of the tank with rubber/steel bush mounts that the screws go through.
After a quick google of images I think Camels use something similar. As does the 125H tank that I'm grafting on to a 2C. The M7 is a guess, but I remember (probably falsely) them being an odd diameter (not the usual M6/M8/M10).
2Cs (and late 350s?) have the horizontal mounts at the rear with rubber bits that go over them with set screws through brackets on the frame.
At the front they have something similar that sort of 'cups' on the inside of the saddle in the tank rest on.
Edit after reading OP properly - and some of the Kanguros same as the Camel? Though I confess I can't find an image to confirm that any did!
Honda: 1984 CB250RS
Ah. I think you have the right of it Mickeymoto. In which case, *if* they are the same as 2C ones I might have a couple going spare.
The steel bush that the rubber cup (30.01.49) pushes on to is 13.04.49 on a 2C and the securing screw is M6x14 (Morini 47.06.24). Maybe the Kanguro one is bigger though?
Honda: 1984 CB250RS
Haboola72
Post by Haboola72 »
X3 tank bolts are tricky.. M8 bolt (10mm in length) with a M6 (10mm in length) riding piggy back on top of the 13mm hex....
M8 to secure the tank , M6 to secure the flimsy and fragile plastic shrouding..
I doubt if NLM have them...you could try
Making them shouldn't be difficult.
Coxey
Post by Coxey »
These last ones sound like what I'm after.
I'll give NLM a call but if they can't help could someone make me up a set in exchange for real money?
Many thanks for your help/advice.
Rob
1989 Kanguro X3
BMW K100RS
Coxey
Post by Coxey »
Update: I've been in touch with NLM and as was suggested, they don't have them in stock (and haven't for years apparently).
So now I'm getting out the begging bowl and asking if anyone who has the wherewithal and willingness to help me out by producing a set to let me know.
Many thanks
Rob
1989 Kanguro X3
BMW K100RS
Haboola72
Post by Haboola72 »
Coxey,
I'll pm you....
