Hello All,
Morini racing update,,,,,,,,,,
In June, high winds stopped the Event shortly after it got started so it didn't count....
Tomorrow is the July Event, and the Baron will be there reconfigured to comply with the (new this year) "M" class specs...
Big Tail is off , a smaller front fender is fitted, fairing forearm covers are on, and one tooth larger on the rear sprocket are the changes from May specs  .....
The record is 120 mph and we'll see what the Morini can do this time around.....
Wind should be ok, but it will be Hot....105 degrees forecasted  for today and tomorrow...
We have an early run position and are hoping to run before the heat and wind get high....
I'll post a picture and info Sunday evening....
Robert in California
						Subercharged Morini heading for El Mirage Again
				texaskitty
