All sorts of bits # 1
Tom
Post by Tom »
Grimeca front mastercilinder/ lever for Kanguro/ Camel and Excalibur, was working when dismantled 30 euro's
Grimeca's Front and back Kanguro 350 Camel 501 X2 and Excalibur 350 501: 45 euro's 25 euro's a piece.
Brake anchor plate powdercoated for the Grimeca rear brake a shown above: 15 euro
Kickstarter for all Enduro's SOLD.
External bearing for pick up rotor SOLD
Headlight Excalibur, same glass a Kanguro Camel XE and X2 20 euro's
Footpegs/ brackets Excalibur New York (can be made into a set of rear sets: cafe racer style) 15 euro's
Powdercoated parts, battery tray 350 for bigger battery (electric start), jiffy stand 350/500 SOLD, kinky frame and Kanguro/ Camel engine mounts 15 euro's per piece or set.
tomros@live.nl
The Netherlands
Ian_C
Re: All sorts of bits
Post by Ian_C »
Hello Tom
Does the headlamp have a glass marked CEV 244 in it?
My X1 glass is cracked so looking for a replacement glass if possible.
Best regards
Ian
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
Tom
Post by Tom »
Hi Ian,
I don't think so, it's the same as the front light of the square type frame Kanguro's/ Camel's, the XE and X2.
Kanguro X X1 had a different type of narcelle/headlight, but i will drop the number of this one when i have checked.
Tom
adrianb
Post by adrianb »
Hi Tom,
Do the master cylinder have a brake light switch on these units and what size cylinder is it? I'm after a replacement for an early 500.
Adrian
Tom
Post by Tom »
@ Ian, it's a CEV 254
@Adrian, yes there is a little switch /brake light indicator. It thinks it's a 13 mm. Morini used this size to operate their smaller 32mm 'Enduro style' calipers.
The 39mm piston Grimeca calipers (350) used 16mm master cilinder, the 41mm calipers and twin disc set up (500) had a 19mm master cilinder.
But i will check on this one, because the caliper you see it not the enduro caliper, also the Excalibur used a single 260mm disc.
Tom
Tom
Post by Tom »
It's a 12 mm piston for the Grimeca.
So, will be to small for your 500 is guess..
Tom
Ian_C
Post by Ian_C »
Tom
Thanks for checking the headlamp glass number for me.
On another question, is there a source to obtain a spare ignition key? My existing one is a CEV one with a number on it
Ian
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
Tom
Post by Tom »
A key specialist can remake the key, they even can do it with/ if you only have / the ignition lock.
Did this with a Kanguro ignition switch once, worked fine!
Tom
Daddy Dom
Post by Daddy Dom »
