Hello all,
Supercharged Morini had a bit of a bad incident and is in need of a replacement swingarm...Among other things....
There is one on ebay here in the States that looks to be off a 500 possibly...Does anyone know if there a  "differences" from a 350 K2 swingarm that would keep it from fitting properly?
I have a swingarm from an early model 350. However, IT would have to have the axle slots machined to fit the larger K2 axle, a brake caliper bracket stay made and welded on "exactly" correct, and addition bracing added to bring it's stiffness up.... All of which I'd like to avoid.
THe motor transmission needs all my attention right now as serious damage is expected to be revealed when I get things apart...
Dyno operator shifted the Bike into 1st with the 1000 lb+ drum spinning 50mph or more......Ugly things happened....
Robert In California
						Supercharge Morini has a bent and twisted Swingarm
Re: Supercharge Morini has a bent and twisted Swingarm
Ow! - sounds nasty.
If you look for 'schwinge' for Moto Morini on ebay.de there are a couple
Good luck.
Good luck.
Bimey! That does sound nasty. I think the 500 item will fit the same, but is a bit longer. So the need for bracing is likely to be even more. I do have one here in UK that is spare but quess the postage will be a bit fruity.
Thanks for the offer Mr. Brown,,,, very nice of you..
I have located on here in California and will be checking it out this weekend..
All help getting the Supercharged Morini going again is welcomed ......
Thanks to all you gerat UK riders!
Robert in California
