Anyone know about these gauge mounts?
holeinthehead
Post by holeinthehead »
Hi All,
Getting my 77 back together and I'm planning for the gauges now. When I got it, there were no clocks, just this bracket - complete with the little Morini badge.
Now that I've gotten my hands on a 350 speedo, I can see that it's drastically smaller than these mounts - they seem to be original to the MM, but are a lot bigger than any gauges I have seen.
These brackets mounted on the fork tube caps. Anyone know more about these?
texaskitty
Re: Anyone know about these gauge mounts?
Post by texaskitty »
They are from an early Strada. The tacho and speedo fit into rubber mounts, which fit into the brackets. Warning lights fit in the small holes. http://www.startgomma.com show the rubber mounts on their web site for 80 euro a pair.
NLM may have the "sleeve couplings" (pattern replacements) 46.03.08 at a lower price. You may also need the sleeve cover 32.01.25 and clips 26.01.25.
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
holeinthehead
Ah - thanks guys. That makes sense. Would love to use them, but 80E is a bit too precious. Will check w/ NLM or have a local cutter do a little bracket for me.
George 350
Post by George 350 »
It is always worth rubber mounting the clocks, else you will find yourself paying out for repairs as they will probably vibrate to pieces!
It is worth asking about s/h parts as well - they don't usually wear out. There are a few people who advertise in ATG, otherwise try a wanted ad on the forum.
Regards,
George.
hendre
Post by hendre »
I'll take the early strada mount off your hands if won't use it... :mrgreen:
huub
Post by huub »
does the early 350 sport have a different mounting?
mine came with the same bracket.
holeinthehead
Thanks all - they're actually exactly what I wanted to use for my gauges, but I didn't know about the rubber bits. Makes sense.
Going to hold on to these for now, but will have quite a few bits to offer up when this one is back on the road.
