Drum rotates about 270 degrees
condition of shift pawl and detent
I was complete up to here with the restoration until I tried shifting the transmission
Back to a dissasembled motor and scratching my head
Advice much appreciated!
I did not but last night I did remove the two nylock nuts and found there is no adjusrtment to the plate.72degrees wrote:Did you remove the 'stopper plate' as part of the strip down?
