Piston ring spring
Tim Louth
Piston ring spring
Post by Tim Louth »
Hi all, question of the day regarding the 350 Sport K1. Can anyone explain why there is a spring behind the oil control ring on the front piston but no spring behind the oil control ring on the rear piston. Many thanks.
Re: Piston ring spring
Sorry, cannot answer why, but the rings I bought before Xmas both had the spring. Apparently this is the way to go.
My K1 project didn't have a spring on both pistons.
Tim Louth
Post by Tim Louth »
Did you put springs on both pistons?
I am in the process of rebuilding my engine and am not sure on the best way to go.
I cannot remember about this either but I should have a set of pistons removed earlier from the bike (which were new) and another set of barrels and pistons. I will have a look at them all when I get a chance.
Tim Louth
Post by Tim Louth »
Thank you.
Tim Louth
Post by Tim Louth »
My old pistons don't have a spring behind either oil control ring.
No springs on mine.
Tim Louth
Post by Tim Louth »
Thanks.
After much thinking, which made my head hurt, I spoke to Chris from NLM and decided to go with springs on both.
