Air filter
Air filter
Hi all, I have just had the timing chains and a dyno done on my 2008 Corsaro Veloce and am very happy with the result. When I picked the bike up the mechanic pointed out that the air filter needs replacing as the rubber edging is starting to break up. I thought this would be a straight forward exercise in finding an aftermarket replacement but no luck. The current filter is a BMC unit that I purchased a few years back so I contacted the BMC agents in Aust and they advised that they don't have any records of a filter being available for the bike. Is the filter common to other marques or is anyone aware of where I could locate a replacement?
Re: Air filter
ben, at amore moto uk has air filters not sure if they are bmc. 07971012660 email bwylie@motomorini.eu
Re: Air filter
I have good experience with DNA but they too do not have a replacement yet... maybe I should sned them my spare airbox so they can add it to the product line
Re: Air filter
there may be a chance that DNA will put Morini 1200 air filters in production... I'll keep you posted!
just to make sure: all 1200 air filters are the same... or not? ( know the Granpasso has a different one but all Corsaro, 9 1/2, 11 1/2 are the same as far as I know)
Re: Air filter
Why are they being changed? I bought the BMC cleaner and oil and re use the filter.
Re: Air filter
cleaner and oiling will still leave some stuff in there. And the characteristics of the filter will be different, I am very happy with DNA on my Duc SC and Guz V7
Re: Air filter
The red polyurethane border started breaking up and the guys who replaced the timing chains recommended I replace the filter to avoid the risk of something breaking off and entering the engine.
Re: Air filter
I have sent my airbox and stock filter to DNA a while ago, there should be a replacement anytime
Re: Air filter
Hi mate,
try Motociclio in St. Peters/ Sydney or
Centrel Coast Motorcycles.. both ex Morini Dealers
with a bit of old stock left over..
best Andre
best Andre
Re: Air filter
Ordered one from amore moto uk and when it arrived the poly edges were broken in the packaging! Returned to Ben and replaced so all good.
Re: Air filter
it took a while but I have recieved a sample DNA replacement filters for the early 1200 airboxes (9 1/2 and Corsaro)
I will post pictures this week, does anybody know exactly which models fit part number M82210001400 and M82200001400 (seem to be identical, first is corsaro number second 9 1/2)
Re: Air filter
pics! left the original BMC and to the right the DNA replacement.
Fits the airbox perfectly!
Anybody knows to what models will fit this filter? Original numbers for the filter (for as far as I know) are M82210001400 of M82200001400. For the filter housing I sent them M82020002010 & M82020001010 (ZLM-BV2 & ZLM-CV2).
Shortlist I can trace through the webs:
* all 9 1/2
* all 11 1/2
* early Corsaro's (untill 2009?)
* Scrambler (untill 2009?)
Correct my where I'm wrong... Just started this process to get filter available for MM owners as BMC does not sell them except to certified MM dealers
* all 9 1/2
* all 11 1/2
Re: Air filter
Yup the rubber surround on the air filter on my early 2009 Scrambler is looking like it might break up and it's M82210001400 and I'd like a new one!
Re: Air filter
sorry for the late reply, you can order directly from the DNA website: https://www.dnafilters.com/en/product/M ... MM12N20-01
Re: Air filter
My later Scrambler has a replaceable paper filter.
