Hi all, I have a small quantity of spares for the Corsarino. Included are, 2 pistons both oversize, a few sets of rings for the same, a few gudgeon pins, one exhaust valve and four inlet valves, 2 each of clutch friction plates and steel plates, a con rod, a bag of 5 sets of points, some electrical contacts for lamps I think, 3 kickstart springs, a tappet adjuster and locknut, a speedo drive gearbox, 2 condensors I think are for Corsarino-all those are NOS and unused. Some are a little rusty but will clean up fine. There is also a used cylinder barrel standard I think, used points cover, and a tool box assembly with 'circa 67-70' written on it, lid included.
I can email pics of the lot if you are interested before I put them on evilbay or take them to Stafford show next week.
PM me here if you want to know more.
Corsarino Spares
Corsarino Spares
Re: Corsarino Spares
Is the 'tappet adjuster' the tool ? Im after the tool to help adjust the valves on the 500.
Cheers.
Cheers.
Hi Ross, sorry but no. It's the threaded tappet and locknut I mean here.rossguzzi wrote:Hi,
Cheers.
The parts mentioned above are now under offer, I will update or re-offer them sometime after Stafford when the horse trading is finished.
