Well that was a productive day. Replaced rear rocker cover gasket, I thought I had a bit of a leak but the old gasket still looked in good condition. Will have to wait and see if the leak is cured.
Whilst I was at it, an oil change and cleaned the filter. Checked condition of air filters, filthy so will have to order some more for another day.
And re-sat the throttle cable plastic thingy as previous owner hadn't installed it correctly, plus replaced the pipes from airbox to carbs as the old one had a split in it.
Now need to think about replacing the belt and balancing the carbs.
Productive Day
Re: Productive Day
Result
Want to come and check mine over?
Re: Productive Day
Could do, but it'll probably be me learning more from you
Re: Productive Day
I wouldn't bank on learning from me, I'm a real lazy cow! (but I can supervise and make tea/coffee)
