Does anyone know of a source for a replacement Dart headlamp? Mine is showing its age and is a little foggy.
The part (800049884) doesn't seem to be available, but it looks like it might be standard 4x6" unit.
Any suggestions?
Replacement headlamp
Re: Replacement headlamp
You are in luck as there is one on Ebay right now:
https://www.ebay.co.uk/itm/MOTO-MORINI- ... Sw3qJbl-So
Wow, that's a stroke of luck! Good spot Tom, thanks.
Pfeil_400
Hi guys,
my newly acquired Dart 400 shows further scars of a hard past life when disassembled: The front headlight insert is some Bosch part, glued in with silicone and some tape and doesn't really fit well, especially with the curve of the fairing at the front. Does anyone have any idea where to get an original headlight?
Thanks and best regards
Matthias
Matthias
- Headlight_Dart_Pz.jpg (81.09 KiB) Viewed 3388 times
Getting very hard to find!
The dart 400 had a slightly different headlight to the 350 I believe- they tend to protrude from the fairing rather than being flush like on the 350. Presumably a homologation requirement in some market the 400 was sold in.
But the more flush type like the 350 looks better in my opinion.
I’m not sure what your headlamp is- certainly not correct, and the dart doesn’t have a full headlamp shell like yours- it has a sealed headlamp unit contained within a black plastic frame.
This should be the part you need (correct type for the 350’at least):
www.ebay.co.uk/itm/334698146010
Pfeil_400
Thanks again! I bought this headlight on eBay!
