Camel/kanguro front fork preload sleeve
elektrobank
Post by elektrobank »
Hi All!
My 501 camel front fork has missed the spring preload sleeve/spacer inside the fork, just under the plug on the top, no the bike is lower on the front a little bit, please someone know how long these pieces are?
Thanks in advance
Gianluca
cosworth
924T
Camel 501
Re: Camel/kanguro front fork preload sleeve
Hi Gianluca, which 501 Camel do you have?
Early small tank with 6V/12V electrics or the later model which has a large tank with 12V electrics/electric start; as their forks are different.
The early small tank 501's pre-load sleeve is 70mm long with an outer diameter of 32mm and it is 1.25mm thick.
Sorry I don't have any measurements for the later forks.
Hope this helps, take care yet have fun, Ian
elektrobank
'It must be a .....' wrote:Hi Gianluca, which 501 Camel do you have?
Thank you very much Ian!! I have a 501 non electric start, will fabricate the sleeves as soon as possible!
Thanks!
cosworth
924T
Camel 501
