Flywheel Holder
Flywheel Holder
I don't suppose anyone in the Midlands has one I could borrow for about 10 minutes! 1977 350 Sport - no electric start.
I've tried locking the bike in gear (clutch not holding enough) and a strap wrench on the flywheel but to no joy. Need to do a cambelt change so I can send my friend his puller back!
Re: Flywheel Holder
Whereabouts in the midlands?
Re: Flywheel Holder
I'm just N of Coventry - near jn2 on M6.
Re: Flywheel Holder
6. gear and rear brake will do
Re: Flywheel Holder
no. It didn't.norbert wrote:6. gear and rear brake will do
Re: Flywheel Holder
At Morano-sul-po rally in Italy two men a wheel brace and a mallet undid the nut on my wifes 250 2C after the belt snapped
Shock treatment
Or a rattle gun.
Shock treatment
Or a rattle gun.
Re: Flywheel Holder
If your clutch slips trying to undo the flywheel nut you have another problem to resolve!
I use a 700mm breaker bar on the nut using Norbert's method.
Re: Flywheel Holder
It hasn't been on the road since an NLM rebuild in 2010 (hence the need for a new belt despite no miles on this one) so I'm sure I will have several problems thank you.MickeyMoto wrote:If your clutch slips trying to undo the flywheel nut you have another problem to resolve!
Re: Flywheel Holder
You're welcome!
