SOLD: First series Gaskets (base and head)- clear out
NOS 1st series gaskets, fibre with copper fire ring on the head gasket , only for use with stepped liners as in picture.
62mm for 350 up to 1979
13 pounds including UK postage.
The cognoscenti always check the lower gasket of original machines. :wink:
I have also one 66mm fibre head gasket - free just pay postage.
Stubaker58
Re: First series Gaskets (base and head)- clear out
Post by Stubaker58 »
Hi Mark,
I’d be interested in the gaskets. PM sent
Stuart,
PM sent, do you still want?
bizzywizzy
Post by bizzywizzy »
If Stuart doesn’t want them I would like them.
Mike
Stubaker58
I’m not sure they are right for my bike (it’s a’79) so you take them.
Regards,
Stuart
Thanks Stuart,
The factory changed to the aluminium gaskets around 79.
This would be about the time of 350 electric start introduction and other engine changes
The blue manual published 1979 I think, clearly shows aluminium gaskets being used.
and in use on earlier engines, which is fine, if you use the sealant.
Athena list the gasket 1974-1978.
http://www.athenaparts.com/eng/products ... ead-gasket
I have 2 engines of the 14XXX range that are from 78 with the stepped liner.
Mike PM sent
bizzywizzy
mbmm350s wrote:Mike PM sent
Hi Mark,
I replied earlier.
Mike
