Foot peg rubbers
Foot peg rubbers
Anyone know a source for the front footrest rubber inserts as per the later Camel/Kanguro/Coguaro( well I presume the same) ?
It is the push in type retained in my case by 2 rubber “studs “ ( not the right word) on the underside of each insert.
70 x25x16mm ish
Re: Foot peg rubbers
Startgomma seems to do most of the rubber bits for Morinis, haven't looked for those yet though. I probably have a few manky examples of them lying around though, If I can find them you're welcome to them!
Hi Steve
Thanks for that.I shall continue to look.I have also some larger pegs which were fitted when I got the bike and obviously any rubber gets slippery when muddy which is a negative. I may revert to those.
