Flywheel
walkermarra
Flywheel
Post by walkermarra »
Just in the process of putting the box of bits I bought together, put new cam belt on engine turns fine replaced flywheel engine does not turn !
According to Diagram on crankshaft after replacing cambelt there should be large washer, spring, circlip, spring, flywheel, spring washer then nut. Is that correct ?
Thanks for any help
Duncan
Re: Flywheel
This video should confirm sequence
https://m.youtube.com/watch?v=TRGUB3hesTk
I have been know to fit the guide washer backwards once so it fretted the edge of the belt.
Can the flywheel be binding against the coils? If so better double check before anything gets damaged or hot. You could fit the flywheel without the coils perhaps to see what happens and /or ink the inside surface with a marker pen then you will easily see any binding points.
Best of luck.
walkermarra
Re: Flywheel
All done, Allen screws holding stator plate to big, fitted dome heads all done.
Thanks for your input 3pot john
Re: Flywheel
walkermarra wrote: 27 Mar 2021 13:21 ... Allen screws holding stator plate to big,...
Been there, done that. Good luck with the next puzzle.
