I really need the boss with connector to the rod in good condition. The pedal part itself is not so important.
I'm on teleborian1@gmail.com
Simon
Wanted 350K2 rear brake lever
Re: Wanted 350K2 rear brake lever
Not sure what you mean here, by boss do you mean the clevis to connect to the rod? If you can post or email a pic that would help. I may have a pedal to suit and a rod with both clevis ends too. herrflick.sb@googlemail.com if you need to email pictures.
