500 & 350 brake pads
Does anyone know whether the brake pads fitted to 350 Sport and 500 Sport models are the same?
Thanks,
Charles
Thanks,
Charles
Re: 500 & 350 brake pads
Possibly. However, they used different Grimeca calipers from around 80/81/82 onwards. Can you post a photo of your calipers?
DD
DD
Hi DD,
Thanks for your reply; please find attached 3 images of the front calipers - hope that these help but if insufficient clarity etc please let me know.
Ciao,
Charles
Ciao,
Charles
- Right Hand Caliper_Rear View
- Right Hand Caliper_Back View_IMG_3181.jpg (99.2 KiB) Viewed 8096 times
- Left Hand Caliper
- Left Hand Caliper_IMG_3179.jpg (115.17 KiB) Viewed 8096 times
- Left & Right Hand Calipers
- Left & Right Hand Calipers_IMG_3180.jpg (119.31 KiB) Viewed 8096 times
Those are the earlier type calipers as fitted to the 350s too. From 1976 till they went to the later type. FA76 is I think one manufacturers code for them. I can check tomorrow as I have just bought a set!
Hi Steve and Dom Daddy,
Thanks for your replies and, Steve, I look forward to getting confirmation on the code when you have been able to check.
Kind regards,
Charles
Kind regards,
Charles
Yes, I forgot that! EBC code is FA076 and you should be able to cross-reference that to other makes.
Thanks Steve. I will check the EBC site and see what it offers. Thanks again for taking the time to check, it is much appreciated.
Adios,
Charles
Adios,
Charles
On a similar point, when I stripped down the calipers on my 1978 500, I noticed a small spring clip which I assume was fitted to stop the pads from rattling. However, the replacement pads I've bought from Mdina do not include these clips. I haven't got around to reassembly yet, but are these spring clips necessary?
