I have a PHBH 26 carb that is missing the screw-in brass breather-tube. Its the vertical tube with the hex that you have a breather-tube on or use as the "take-off" for balancing your carbs.
Anyone have one spare, or a worn out carb I can pinch one from? No longer listed by Contact Dvlpments
PHBH 26/28 BREATHER Wanted
