Looking for Power/Torque curves for the Corsaro
shacard
Post by shacard »
With our 100 horsepower limitation, we have no review in France of the 140hp Corsaro. :(
Does someone have a review with the power and torque curves ?
A+
corsaro chris
Post by corsaro chris »
Go to www.morini.de; this is the German Morini web site and they have a lot of information on the various Morini models - including torque and power curves.
The factory Moto Morini web site also has a section on the engine, but it is far more arty and less use these days... The Sport is as nice (if not nicer) to ride, and puts out less power with a lower fuel consumption.
Good luck,
shacard
Post by shacard »
Thanks Chris.
I have found this on their website :
But i would like to see the same thing from an other source than MM itself :wink:
I will do a scan a our french curves.
A+
shacard
Post by shacard »
The power curve :
But i'm still looking for the torque curve.
shacard
Post by shacard »
shacard, you can draw your own torque curve from the power curve you have, just read off the graph the ps and engine speed at as many points as you like and then plot your torque curve using the formula:
Torque (Nm) =power (kW) x 60000 \ (2 x pi x engine speed (rpm) )
You can convert from ps to kW by multiplying ps by 0.74
Hope that helps but all you really need to know is the corsaro has buckets of torque
shacard
Post by shacard »
Thanks Tom.
Have you read reviews of the Corsaro in english magazins ?
I have still not find the acceleration times of the Corsaro and things like 60-100km/h or 100 to 140km/h in 6th gear.
