Indicators 350 sport
Posted: 16 Jan 2022 15:47
by Matt Hale
Hi all- can anyone confirm what bulbs to use in indicators on 350 sport? I mean what watts. 12V 23W won’t work it seems. I bought some aftermarket that came with that size and nothing happens except the other linked indicator goes faster…should they be 15W?
All advice welcome!!
Re: Indicators 350 sport
Posted: 16 Jan 2022 17:16
by MickeyMoto
21 watt. What do you have for a relay?
Posted: 16 Jan 2022 19:16
by Matt Hale
Hi Mickey
Thanks for your answer! 21 Watt bulb... I am afraid I am not sure what relay I have- I can't look as bike not with me now...do you know what it should be? I have looked in manuals I have but no info I can see..would this one do- Classic Motorcycle Flasher Relay Unit 12V - 18/23W 3 Pin With Rubber Holder Ex Quality. <
https://www.classicbikepartscheshire.co ... 3ZEALw_wcB>
Much appreciate your help.
Matt
Posted: 16 Jan 2022 19:42
by MickeyMoto
Yes, something similar. I'll look at mine later, much later, as not home until Friday.
I paid about £3 from a motorcycle shop.
Posted: 16 Jan 2022 20:07
by robint
If you are happy to tweak the wiring a bit then electronic relays are much better giving a steady flash rate - rather than the somewhat variable one from the older bimetallic strip type of relay. Also independent of load.
Posted: 17 Jan 2022 14:43
by AntietamClassicCycle
robint wrote: 16 Jan 2022 20:07
No need to "tweak the wiring a bit", an electronic flasher connects exactly the same. One really only needs a flasher with two pins. I have this one on my Morini and it works perfectly well.
https://www.amazon.com/gp/product/B07MJGC28B
Posted: 17 Jan 2022 15:05
by 3potjohn
http://www.norbsa02.freeuk.com/goffyindicators.htm
My indicators came from vehicle wiring products and run well. Certainly better than those 23 w mini indicators folk use which cannot be readily seen on the motorway. And lightweight compared to my originals.
Posted: 17 Jan 2022 18:34
by MickeyMoto
Just use your arms on the motorway!
Posted: 19 Jan 2022 08:57
by Matt Hale
Thanks to you all for this advice on my indicators. Life is good with your help! All sorted now- turned out to be a wiring issue mostly...
Matt
