Wanted for 500 Sei-V
Looking for a couple of bits for my current project.
First a pair of front indicator stems. The ones I have are 10mm thread one end and 8mm thread at the other. As far as I can make out the stems should screw straight into the headlamp shell. I suppose someone may have mounted them elsewhere but I don't want extra brackets etc. If not I may knock something up on my lathe but I'd prefer standard bits here if possible.
Secondly a dualseat for the same bike. Mine has a Sport seat in good condition but I want this bike to be pillion friendly. In case I ever make friends with anyone.
Edit! And thirdly I would also like a plastic lower chainguard, the shorter one fitted below the chain and swing arm.
And while I'm adding bits, the spring for the seat catch plus screw and washers etc would be good.
AND!! Does anyone have any of the rubber bump stops for under the seat to spare please?
Re: Wanted for 500 Sei-V
I know I have at least one lower chainguard. If I have more than one, Im happy to part with it.
If you have no joy with the rubber seat bungs, I have guzzi ones which screw into place and will be better than nothing
Simon
Simon
Thanks Simon, let me know what you find please. As for the rubbers, at the moment a couple of door stops are doing the job! Not pretty but...
Ok ive found one!
Just back from Telford. I'll be going to Shepton show if you are able to take it there?
Simon, I'm at Shepton. Are you here tomorrow? Got the Sport yoke for you here.
Sorry Simon, got my messages mixed up. Ignore that!
Apologies, was on Exmoor with absolutely no signal all weekend
