It'll be a standard bearing - but what size / reference?
A back up query, just in case I can't get any from my 'normal supplier'...
It's loose at 24,000 miles; I'm told it's because I clean the bike (so that cannot be true, surely?)
Rear Wheel Bearing sizes
- corsaro chris
Re: Rear Wheel Bearing sizes
The only proper way is to remove the wheel and look on the bearing. Or the parts book. The bearing should be sealed, unless you use a pressure washer they should last.
Do you torque up the rear wheel? The ft in the torque figure means @#$%^&* tight.
