250 2c carb to airbox manifolds
Parker3865
Post by Parker3865 »
Would anyone have the connector pipes and joiner/bush from the carbs to the airbox for the 250 2c v twin. Both sides needed. Part No 30.01.61 x 4 and part No 32.01.48 x 2.
Richard Parker
Re: 250 2c carb to airbox manifolds
Post by simonnorthroad »
Ive got one Richard, if you dont find two used. Im in Bath
Parker3865
Thanks, I'm in Brentwood,. My daughter at Uni in Bath so I'll let you know if I need it and talk about price than. Many thanks.
hombre
Post by hombre »
Startgomma has those for 125's, don't know if they are the same?
Hello Richard
30.01.61 is same part on Kanguro X, airbox side.
The coupling ring is just a hard plastic stiffener thing - you can 3D print that!
I can measure one for you if needed if no one has them.
The 250 2C uses the two right angle parts coupled together, using the stiffener ring- bingo!
replacement Kanguro part is here:
https://www.startgomma.com/en/manufactu ... ESC&page=3
Buying 4 is a little bit expensive , so hopefully some kind souls have Kanguro ones.
Parker3865
Thanks for that, very useful information. I'll come back to you about dimensions of the connector if I need to.
As far as I can see, 30.01.61 is the 90 degree rubber 'elbow' with MM50 moulded in so yes the same as the Camel Start Gomma V619?
For some odd reason I have 3 used ones in the odds and ends box in the shed. There must have been four when I 'broke' the 250 that became the Forgotten Error. No stiffening rings though.
I won't be using them. Postage will be about three quid.
PM me with an offer.
Parker3865
Many thanks for all the help. I am sorted now, thanks to the community.
