Electronic ignition.
rossguzzi
Post by rossguzzi »
i have just started lookng at what is possible to do to the 125's incase I get one.
Anyone had experience with https://www.powerdynamo.biz/eng/systems ... 76main.htm
I know points and condensers can play up, so just curious.
Cheers.
Parker3865
Re: Electronic ignition.
Post by Parker3865 »
Used a Vape system on my Garelli. 6 to 12v conversion. Very well made if expensive, but fitted it and haven't had to adjust or play with it since.
rossguzzi
Post by rossguzzi »
Thanks for the reply. Cheers.
Points and condensers are simple though and if necessary probably a roadside repair. IINBDFI
Arthur Farrow
Post by Arthur Farrow »
My 1960 175 Tresette has the full power-dynamo/Vape ignition and generator set up. Runs better than ever and HIGHLY recommended but a bit expensive and needs a fair amount of rewire. You know the bike is worth it. 750 trouble free miles last year.
Lights work excellently and battery always charged and no de magnetism of old flywheel issues.
FABULOUS!!
ARTHUR
