Oil pump seal variation in sizes/mdina part different?
R1100purist
Post by R1100purist »
Hi all,
I am doing a clutch side tear down to sort a leaking clutch seal. My oil pump seal (green) looks a little worn too so I figure I’ll swap him out too. However when digging through my spare parts, my oil pump seal from mdina appears to be of tool small outside diameter to be a press fit within the oil pump housing like the original is. What gives?
Re: Oil pump seal variation in sizes/mdina part different?
I have used the black one but I prefer the old green one. Check the green one carefully, obviously not worth the risk if it is worn.
The black straight tube type seals is all that has been available for some time now. I too prefer the original and have re-used them many times. The rubber seems pretty resilient and so long as it isn't cut, nicked or otherwise damaged/degraded they can go back in.
I haven't heard of any problems with the new seals but have only used them a couple of times.
R1100purist
Thanks all! The new smaller diameter one just makes me nervous. I would say my original just has a little scuffing on the tapered section. Really wrinkles where it looks compressed but it still pliable. I’m still pondering if to re-use. I may just clean up and throw some silicone grease on for good measure?
From what you say it sounds a possibility to use it again. As long as it is still rubbery, not cut or split etc. When you come to fit the case you should be able to just feel that rubber being compressed, only by a tiny amount. If the gasket faces are good you could omit the gasket and use 3 Bond or Silicone sealant (sparingly) and that will give the rubber an extra pinch. Have done that a few times when a new gasket wasn't available. No evidence of any problems either.
