Front fork leg’s alternatives?
Motomat350
Post by Motomat350 »
Hello all morini experts :D
I’m looking for a new set of Marzocchi legs for my 3 1/2.
Can anyone suggest other legs than tnk/TAROZZI Marzocchi remakes?
It seems that Ducati pantah and Cagiva sst250 might be the same? - but I can’t get it confirmed..
Happy biking :D
George 350
Re: Front fork leg’s alternatives?
Post by George 350 »
Pantah ones can fit straight on, but it depends on what year your bike was built. My '78 Strada has them (Tarozzi) and they are good now, but I had to make up various spacers to make them work. Others have fitted them without issue as they were the same as their old ones. To me, they are well made and worth buying if your bike is in the right age bracket.
Whether Allbike Engineering in London can help I don't know.
Other options are getting what you have replated (eg. Philpots in Luton).
As for other bikes, the only likely candidates other than the Pantah are probably few and far between, and extremely rare now.
Regards, George
Vitesse
Post by Vitesse »
The Cagiva SST250 (Or Harley Davidson as mine was badged years ago!) seems a poor choice as they are very uncommon over here. I'd also be surprised if they are a suitable length as those are much taller, more upright bikes.
Motomat350
Thanks for your suggestions. I have a possibility to pick up a set from a cagiva sst250 for a reasonable price. I guess the chance for a propper fitment, is as good or bad as a set from a Pantah. I think I'll give a try..
Post by simonnorthroad »
Ive got Pantah fork legs etc amongst my spares.
Be advised though, that the Ducati/Guzzi Brembo P5 caliper mounting bolt spacing is not quite the same as the Morini Grimeca
huub
Post by huub »
Motomat350 wrote: 12 Apr 2024 11:56 Thanks for your suggestions. I have a possibility to pick up a set from a cagiva sst250 for a reasonable price. I guess the chance for a propper fitment, is as good or bad as a set from a Pantah. I think I'll give a try..
check the diameter ,
i have a set from a cagiva that are 32 mm diameter instead of the morini's 36 mm.
