My bearing spacer for the rear wheel is seized to the bearing outers. I intend destroying one bearing so I can knock out the other then remove the remains of the bearings from the spacer. I may end up ruining the spacer.
Just in case, has anybody a spare cast rear wheel bearing spacer, please? Part No. M430662
Thank you.
Edit: After a few hours in the garage I managed to dremel my way through one bearing, knock out the other with the spacer attached and the remains attached to the other end. I then managed in the vice to remove the bearing and the remains. The spacer needed a bit of dressing but all done.
(No longer) Wanted - rear wheel bearing spacer
